Expect scripting problems
deehusky79
Frequent Visitor
Frequent Visitor
Hi, I'm a newbie in expect. I need a help to figure out couple things with this script:
#Specify all our commands in a list, that we will issue one by one at a later time.
set commands [list "conf t" "do sh ver | i uptime" "do sh clock" "end"]
#set prompt "#"
set prompt {([#>]) ?$}
foreach device $device_list {
        # Set each device's log file to be the name of the device...
        set file_name $device
        set timeout 30
        # we initiate the login connection
        spawn ssh $device
        match_max [expr 32 * 1024]
        expect -re $prompt
        send \r
        expect -re $prompt
        foreach cmd $commands {
                send "$cmd\r"
                expect -re $prompt
                send \r
                expect -re $prompt
                set output $expect_out(buffer)
                set fd [open $file_name.txt a+]
                puts $fd $output
                close $fd
expect -re $prompt
send "exit\r"
exp_close -i $spawn_id
exp_wait
My problems are:
1. This script runs the commands but the output get altered, eg:
INPUT
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#
R1(config)#do sh ver | i uptime
R1 uptime is 5 days, 5 hours, 56 minutes
R1(config)#
R1(config)#do sh clock
15:27:41.082 NZST Mon May 14 2018
R1(config)#
R1(config)#end
OUTPUT:
conf t
R1(config)#
R1(config)#
R1(config)#
R1(config)#
MISSING: do sh clock
2. How to format the output as per below (the device hostname shows only on the first line).
R1#
conf t
do sh clock
end
3. How to save the output into 1 file only, eg:
~$more file_name.txt
R1#
conf t
do sh clock
end
R2#
conf t
R2 uptime is 6 days, 5 hours, 56 minutes
do sh clock
18:27:41.082 NZST Mon May 14 2018
end
R3#
conf t
R3 uptime is 7 days, 5 hours, 56 minutes
do sh clock
end
Thanks heaps for your time to help me!
Joe Clarke
I'm not sure why you go into config mode to execute show commands.  That seems needlessly complicated.  This version should be closer to what you want.
#set prompt "#"
set file_name {file_name.txt}
set fd [open $file_name w]
        set timeout 30
        puts $fd $device
        spawn ssh $device
        expect -re $prompt
                send "$cmd\r"
                expect -re $prompt
                puts $fd $output
        send "exit\r"
        exp_wait
close $fd
Hi Joe,
Thanks for your time to look at my issue. I use sh commands just for testing. I run your script and some devices missing the last command "end'. Here's the input sample (R2):
spawn ssh R1
R1>conf t
en
Password:
R1#conf t
R1 uptime is 1 week, 3 days, 59 minutes
10:20:34.239 NZST Tue May 15 2018
R1(config)#end
R1#
spawn ssh R2
R2>conf t
en
Password:
R2#conf t
R2(config)#do sh ver | i uptime
R2 uptime is 1 hour, 48 minutes
R2(config)#do sh clock
10:20:40.020 NZST Tue May 15 2018
R2(config)#
spawn ssh R3
Could you also explain to me what the purpose of match_max [expr 32 * 1024] please. Can I expect the buffer is big enough to copy the output of 800+ devices?
Thanks Joe!
