04-26-2023 11:43 PM
I have 28 switches on my company.
To config, I was export config file.txt from the first switch and import config file.txt to another switch, one by one.
Then I manual edit IP, name, .... then I config trunk port, access port and connect to access point.
Some users cannot connect Wi-Fi or sometime disconnect Wi-Fi suddenly.
I checked DHCP server, Wi-Fi controller, they are correctly working.
Please tell me, that way to config Switch is fine? Any problem with this way?
Thank you.
Vui
04-27-2023 02:40 AM
nobody can help? please
04-27-2023 02:55 AM
can not connect to Wifi and some times disconnect ?
check the port connect to AP is it trunk ? are the VLAN allowed must be different ?
04-27-2023 06:57 PM
Thank for your rep
-> yes.
-> The port connect to AP was trunk and I set allowed all Vlan
