Export maps from NCS 1.1 to CPI 2.2.x
fender100
Hello Support,
the customer wants to export the maps from NCS 1.1 to CPI 2.2.x. Could you please confirm that we can export the maps from NCS 1.1 to CPI 2.2.x without issues?
thanks
AFROJ AHMAD
Exporting map is supported ,hopefully there should not be any issue.
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/guide-c07-731626.html#_Toc386763606
Thanks-
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks!
