Export tool in CW not work
wael_ashraf
Hi Experts,
     I have LMS 3.0.1 working on windows 2003. when I tried to export any report to csv or pdf, I got it's not worked. a blank window appeared  and disappered repidly. Do you have any idea how could I fix this issue?
Thanks in Advance
Best Regards,
Tri(7)ple
aieremias
I had this problem too and found this in Common Services User Guide:
In Microsoft Internet Explorer 6.0 SP2 and Microsoft Internet Explorer 7.0 browsers, sometimes
problem occurs while exporting the reports in CiscoWorks applications to a PDF or CSV format. This
problem occurs on a Windows XP client machine.
This may be caused by the default security settings in the browsers.
To enable exporting reports in CSV and PDF format in Internet Explorer browsers:
Click Tools > Internet Options.
The Internet Options dialog box opens.
Click the Security tab.
Click Custom level... from the Security level for this zone panel.
The Security Settings dialog box opens.
Select the Enable option for the File Download field.
Click OK.
BR,
Alex
aieremias
Click OK.
BR,
Alex
Hi Alex,
     thanks for your help. it's helpful. but the issue in my system was in enabling "Automatic prompting  for file downloads" not file down. and it's working now properly.
BR,
777
