06-06-2016 02:00 PM
Hello
I'm looking forward to exporting a list of all my hardware with hostname and serial number.
Anyone has any idea how? Exporting the inventory does not display serials. On the other hand, serial appear in the device search page, but there is no way to export there.
Solved! Go to Solution.
06-06-2016 04:17 PM
On CPI3.0, you have to go report and select detailed hardware under device.
See screenshots.
Please don't forget to rate and select correct answer if this solve your question.
06-06-2016 04:17 PM
See screenshots.
06-29-2016 07:27 AM
Spot on !
Exactly what I was looking for.
Thanks!
06-29-2016 07:43 AM
Thanks. You're very welcome
09-20-2018 11:08 AM
I have PI 3.3 - ran the report and it returned no serial numbers.
10-15-2018 01:18 AM
