Exporting selected counters to syslog
sprocket10
Level 2
Level 2
Currently I am running this part of a script to export the entire result to our syslog. However I only require 2 parts from the output (highlighted in below output). I have other scripts that do this, but as both lines start with a non consistant counter I am unsure how to pick out this data.
I would usually have something like: action 040 regexp "(Configured .*)" "$_cli_result" match line
Currently use:
action 030 cli command "show interface cellular 0"
action 040 regexp "(.*)" "$_cli_result" output
Output:
Cellular0 is up, line protocol is up
  Hardware is 4G WWAN Modem - Global Multimode LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS
  Internet address will be assigned dynamically by the network
  MTU 1500 bytes, BW 50000 Kbit/sec, DLY 20000 usec,
  Encapsulation SLIP, loopback not set
  Keepalive not supported
  Interface is bound to Di0 (Encapsulation SLIP)
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 00:11:07
  Queueing strategy: fifo
  Output queue: 0/10 (size/max)
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     472 packets input, 67861 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     508 packets output, 91666 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Mark Malone
for the cli command you could try this ,that should just pick up those two lines
sh int cellular 0 | i input,|output,
Mark Malone
that will do perfectly thanks
