Need Password Recovery
Hellow guyes,
I am facing a problem with one router. I have username and password but its not working on cisco router.  router is enabled login local or AAA, i am not sure becasue its required username and password. I don't have the backup of config.
I want to make user, password recovery procedure is the same as enable password recovery or different.
regards,
Syed
InayathUlla Sharieff
The procedure is same.
http://www.cisco.com/c/en/us/support/docs/routers/2800-series-integrated-services-routers/112033-c2900-password-recovery-00.html#procedure
http://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-121-mainline/6130-index.html
Inayath
Inayath
