EXPORTING TOPOLOGY MAP TO VISIO
ahmedmt786
After exporting the topology map, I'm unable to open in visio, which format we need to save the file?????
Marvin Rhoads
The export format that used to work was comma separated variable (*.csv). MS removed that feature (import csv file) from Visio, Not sure if it was as of Visio 2003 or Visio 2002. I do know that Visio 2000 works. If you can find a back-level Visio installation, you can import there and bring it forward as a .vsd file. I believe the end user license agreement for Visio allows one to use a back level version if a newer one is licensed.
Hope this helps. Please rate helpful posts.
