03-05-2021 02:36 PM - edited 03-05-2021 02:38 PM
Hello Team,
After two weeks of digging, searching, trying, watching and reading I kindly ask for Your help.
I make first steps with FirePower 1010 FDM
What I did after unboxing is:
- registering the license
- Thread/Malware/URL License/Intrusion are disabled
- WAN ETH 1/1 in DHCP mode (10.0.1.14) DNS - Cisco Umbrella
- Firmware update to 6.6.1-91
- Interface 1/8 I have set to access mode, assign vlan 2 and enabled dhcp server of range 192.168.2.10-20
- the vlan is added to inside_zone (standard one)
- I have connected Raspberry PI with open SSH server on port 1234 to int 1/8; Raspberry got IP: 192.168.2.100
- I have enabled rsyslog server on raspberry
- I have connected PC to port 1/2 - got IP 192.168.1.10
- Raspberry and FPW 1010 got internet connection
I am attaching screen - hope the configuration is clear
Team, how to expose SSH port 1234 from Raspberry that PC 10.0.1.20 will be able to connect to it?
I have created various Static NAT rules and Access rules.
I can connect from 192.168.1.10 but I cannot connect from 10.0.1.20
I can not see anything from 10.0.1.20 in syslog server
Firepower itself is pingable from 10.0.1.20
What am I missing?
Solved! Go to Solution.
03-08-2021 02:01 PM
It was a NAT issue.
I have found solution here:
https://integratingit.wordpress.com/2020/02/08/ftd-configuration-using-fdm/
03-08-2021 02:01 PM
It was a NAT issue.
