You need to configure trunk between the 2960 and the one 3550 and one trunk between the two other.
Switch(config)# interface fastethernet0/4
Switch(config-if)# switchport mode trunk
Switch(config-if)# switchport trunk encapsulation dot1q
If your 3550 has 2 gig-links then you might concider configuring etherchannel ?
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a008014f344.html
Bjornarsb
