External DHCP is not releasing IP
jai.s401
The DHCP server is external. (192.168.82.22)
The catalyst is the Core Switch. (172.29.8.1)
We are getting the Following debug log while trying to fetch DHCP to a end machine.
The show-tech log is attached with this mail.
*Jul 18 14:42:19.889: Option 82 not present
*Jul 18 14:42:19.890: DHCPD: tableid for 192.168.82.2 on Vlan82 is 0
*Jul 18 14:42:19.890: DHCPD: client's VPN is .
*Jul 18 14:42:19.890: DHCPD: No option 125
*Jul 18 14:42:19.890: DHCPD: Option 125 not present in the msg.
*Jul 18 14:42:19.890: Option 82 not present
*Jul 18 14:42:19.891: Option 82 not present
*Jul 18 14:42:19.891: DHCPD: Option 125 not present in the msg.
*Jul 18 14:42:19.892: DHCPD: Looking up binding using address 192.168.82.2
*Jul 18 14:42:19.892: DHCPD: setting giaddr to 192.168.82.2.
*Jul 18 14:42:19.892: DHCPD: BOOTREQUEST from 0100.5056.a0eb.87 forwarded to 192.168.82.22.
*Jul 18 14:42:20.390: Option 82 not present
*Jul 18 14:42:20.390: DHCPD: tableid for 172.20.5.2 on Vlan122 is 0
*Jul 18 14:42:20.391: DHCPD: client's VPN is .
*Jul 18 14:42:20.391: DHCPD: No option 125
*Jul 18 14:42:20.391: DHCPD: Option 125 not present in the msg.
*Jul 18 14:42:20.391: Option 82 not present
 As per the Cisco TAC configured the Command set #ip dhcp relay information trust-all globally still getting the same debug log and the end machine is not getting any IP from DHCP.
network Diagram and Sh tech of switch are  attached.
Can you check attachmnet i dont found it.
what is the external DHCP server ? Do you actually have options 82 and 125 configured ? Post the full running configuration of the switch as well...
