Extracting output of customized CLI templates in presentable format either in excel or PDF using cisco prime infrastructure
zffrmohd
Request to help us in exporting output of customized CLI templates in presentable format either in excel or PDF as soon as we deploy on the added network devices under prime infrastructure 3.4 tool.
If we are more precise we have couple of devices added under prime tool where the reports need to be extracted automatically for maintenance inspection check periodically (daily/weekly/monthly/6months/yearly) by specific commands created in CLI template by using Cisco Prime.
We would like to know if there are any tool to integrate / specific way  through Cisco Prime to apply the CLI template and generate this report automatically in presentable format .
Generated reports need to be in any presentable form and able to be exported in CSV/PDF.
0 Replies 0
