SNMPv2 read C4500X Power supply status error !
HI  everyone,
We are occuring a issue that is snmp read the Catalyst4500X swtich power supply status normal, but the real status of power supply 2 is "bad/off". So what wrong with this symptom ?Is it a bug ?
Some information of this issue:
1\OID:1.3.6.1.4.1.9.9.13.1.5
2\we get the value of snmp:
# snmpwalk -v 2c -c xxxxx 10.100.9.1 1.3.6.1.4.1.9.9.13.1.5
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1 = STRING: "Power Supply 1"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.2 = STRING: "Power Supply 2"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.1 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.2 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.1 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.2 = INTEGER: 2
3\The real status of power supply:
Power        FAN             Inline
supply         Model No                      Type          Status                Sensor         Status
PS1     PWR-C4KX-750AC-R   AC 750W        good               good                n.a.
PS2     PWR-C4KX-750AC-R   AC 750W         bad/off           bad/off             n.a.
thanks
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
balaji.bandi
here is the we use solarwinds. 6500 works as expected, Do not have 4500 to test
https://secure.n-able.com/webhelp/NC_11-0-0_en/Content/Help_20/Services/Cisco/Services_PowerSupplyCisco.htm
BB
HI BB,
Thanks for you response!
I think yours oid is the same as mine, i have tried to get the value by oid "1.3.6.1.4.1.9.9.13.1.5" or "1.3.6.1.4.1.9.9.13.1.5.1.3". I got the same value that is "1",which represent normal,even though the power supply has bad/off status.
It's so strange!
