Facing issues with cisco switch 48
Case 1 :
Jun 14 07:06:03.973: %ILPOWER-7-DETECT: Interface Gi1/0/19: Power Device detected: Cisco PD
Jun 14 07:06:04.575: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/19: Power granted
Jun 14 07:06:04.680: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/19: PD removed
Case 2 :
%Error opening tftp://255.255.255.255/network-confg (Timed out)
%Error opening tftp://255.255.255.255/bibujcoswvoice01-confg (Timed out)
Jun 14 07:27:27.857: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
Jun 14 07:27:27.860: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/bibujcoswvoice01-confg) failed
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
%Error opening tftp://255.255.255.255/bibujcos.cfg (Timed out)
Jun 14 07:28:09.884: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
Jun 14 07:28:09.887: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/bibujcos.cfg) failed
biBUJcoSWvoice01#
Can someone assist me with this issue?
Thanks & Best regards
Leo Laohoo
This is Cisco Auto Provisioning (pre-Zero Touch).  What is the question?
Mark Elsen
        - What is the switch model ?
 M.
The model is Cisco swith 2960-X
Check the running config for the command service config. If you find it in the config then remove it and the messages for case 2 will stop.
Rick
