HI ,
I am facing problem in Ciscoworks in Fetching config Archieve from Cisco ASA-5510 Adaptive Security Appliance . I am using LMS 3.2 and RME 4.3.1
SSH is enable in the device, and from LMS server I am able to connect through Putty. Also from Management station to Device it showing SSH is up for both version. But from RME its failing Its giving below mentioned error
| Device: COGINHYDGCBDFHRTF1 Status: Failed |
| *** Device Details for COGINHYDGCBDFHRTF1 *** | | Protocol ==> Unknown / Not Applicable | | Selected Protocols with order ==> SSH,Telnet,TFTP,RCP,SCP,HTTPS | | Execution Result: | | | RUNNING | | CM0151 PRIMARY RUNNING Config fetch failed for COGINHYDGCBDFHRTF1 Cause: Couldnot enter ENABLE Mode from USER Mode on 10.241.44.220.TELNET: Failed to establish TELNET connection to 10.241.44.220 - Cause: Connection refused. | | Action: Check if protocol is supported by device and required device package is installed. Check device credentials. Increase timeout value, if required. |
I have tried from LMS server by telneting to port 22, its giving below output------SSH-1.99-Cisco-1.25
When I have tried to test device credentials for SSH and SSH Enable mode, then below output I am getting. SSH remains blank status.
Pls help to resolve this.
