Fail to Login Switch from Cisco Prime Infrastructure
PolarPanda
Hi there,
          After I setup email alert in SNMP server (solarwinds), I received email alert regarding Cisco Prime Infrastructure failed to login few switches every 4 hours. Can anyone tell me why CPI constantly attempts to login switches? If it's normal, can someone show me how to config CPI to have correct login credential, then I won't receive any login failure emails. Thank you!!
Mark Elsen
 - You are supposed to enter devices with correct access-credentials into Prime. If problem persists remove  the particular devices and re-enter them into Prime but press Verify Credentials first.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you!! Do you know why CPI tries to login switch every 4 hours? Thanks.
 - These are probably maintenance tasks that Prime executes. Don't worry too much ; if you want to know what they are you could for instance activate the logging of configuration commands the commands show below ; afterwards issue show archive log config all (at regular intervals)
archive
log config
logging enable 100
notify syslog
hidekey
 M.
       Beauty and terror
      Just keep going
       No feeling is final
