GeoMap application installation to EPNM failed
rustomhind
I am trying to upload the below Geomap to a freshly installed EPNM VM. I have sucessfully copied the geomap file to the Defaultrepo i am running the below comman for installation. Theversion of EPNM and Geomap both are 2.1
EPNM-1/admin# application install Asia_GeoMap_CEPNM_2_1_0-bundle.tar.gz defaultRepo
Save the current ADE-OS running configuration? (yes/no) [yes] ? yes
Generating configuration...
Saved the ADE-OS running configuration to startup successfully
Please ensure you have a backup of the system before proceeding.
Proceed with the application install ? (yes/no) [yes] ?
Initiating Application installation...
% Unable to unbundle the package. Package may be corrupt or there is not enough disk space
The Md5 for the geomap matches the one on the cisco site. So the file is good.
There is no space issue as i noted the following below.
ade # df -lh
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/smosvg-rootvol
3.9G 327M 3.4G 9% /
tmpfs 24G 9.5G 15G 40% /dev/shm
/dev/mapper/smosvg-altrootvol
124M 5.6M 113M 5% /altroot
/dev/sda1 485M 41M 419M 9% /boot
/dev/mapper/smosvg-home
124M 5.6M 113M 5% /home
/dev/mapper/smosvg-localdiskvol
132G 4.0G 122G 4% /localdisk
/dev/mapper/smosvg-optvol
683G 33G 616G 6% /opt
/dev/mapper/smosvg-recvol
124M 5.6M 113M 5% /recovery
/dev/sda2 97M 5.6M 87M 7% /storedconfig
/dev/mapper/smosvg-storeddatavol
25G 173M 23G 1% /storeddata
/dev/mapper/smosvg-tmpvol
9.7G 151M 9.0G 2% /tmp
/dev/mapper/smosvg-usrvol
6.8G 1.3G 5.2G 20% /usr
/dev/mapper/smosvg-varvol
3.9G 140M 3.6G 4% /var
The installation happens in /opt which as got more than sufficient space to install the geomap
Any help?
0 Replies 0
