Failed to reach remote network when i changed to direct connect lag
wchan1
I have 3 direct connect links. 2 of them bind into a port-channel to form LAG with AWS. Remain 1 has a l2tp tunnel on it and is working fine. the problem is, when i changed to LAG. i fail to reach x.x.x.x:50001(ip is pingable but tcp fail). i don't know the issue is bgp or l2tp or something else? i made a wireshark it seems i can't get syn reply from remote network. appreciate your help in advance.
17 Replies 17
so you can reach x.x.x.x:50001 through the L2TP ? Can you reach anything else when switching to the LAG, that is, is it only that specific port the LAG is not reaching ? It would also be interesting to know if any other of the dynamic/private ports (49152 through 65535) are blocked. If so, that could be an (AWS) security setting...
Thanks your reply. i don't think it is security setting coz 50001 can go through l2tp when i use existing one but fail when i change to other 2 links with direct connect LAG(however ip is pingable). Can i setup l2tp on top of Layer2 LAG?
you don't have any MACsec configured on the LAG by any chance ? Can you post a screenshot of the 'View Details' of the LAG ?
 No in my side, not sure about remote side as i don't manage that.
do you have a diagram of the entire topology (your side and the remote side) ?
this is brief archi. On the other hand, my colleague said i can checkk the NAT. Did i set the NAT properly?
interface GigabitEthernet1/0/2
ip address a.a.a.a 255.255.255.0
ip nat outside
ip nat inside source static b.b.b.b a.a.a.a route-map nat-to-ocg-v2
ip access-list extended 100
10 permit ip b.b.b.b 0.0.0.255 d.d.d.d 0.0.0.255
20 permit ip b.b.b.b 0.0.0.255 c.c.c.c 0.0.0.255
30 permit ip b.b.b.b 0.0.0.255 a.a.a.a 0.0.0.255
route-map nat-to-ocg-v2 permit 30
match ip address 100
set ip next-hop a.a.a.a
the NAT configuration looks good actually. You would have more problems if there were a NAT misconfiguration, as it seems to be just this one port. Can you get the configuration of the other side, or at least, can the other side see incoming traffic from that port at all ?
cannot get config of remote side, i checked with remote side, they can see traffic from that port only with old direct connect(fail when using LAG). Another thing is, remote side only accept packet from my g1/0/2. so i don't what happen between my direct connect and the g1/0/2
Is it possibly route redistribute issue as it contains bgp and static route?
just for clarity: is there ANY traffic at all being received at the remote end when connected through the LAG, or just not traffic from that one specific port ?
nothing to remote when connected with LAG. Thanks
that is a completely different problem then, which requires a different approach. Post the full configs of the devices you are in control of.
Hi, Georg
config here. mask ip due to confidentiality
wchan1
looking forward to your advise. Thanks
