Failover active and to send CGI
farguisito
I have a Cisco 881G and would like to make the following proposal. I have 2 ISPs and would like to activate Failover, I think that I have no problem here but I would like when the main ISP fails and failover is activated, I want to send a CGI to notify a server this issue.
Also when the ISP will be recovered, I want to send another CGI again to recover the initial state of the server.
Could anybody help me ??
Thanks.
Regards.
5 Replies 5
Joe Clarke
Can you clarify what you mean by "CGI" in this context?  Can you provide an example of what the desired flow might be?
Thanks Joseph for the interesting.
I have one PLC and I want to warn it when the ISP 1 is down. Then I don´t know if I can create one script or anything else to get this action.
The method for warn the PLC must be CGI "ip/setParam.cgi?Variable" for example.
What do you thing about this??
Thanks.
Regards.
This is possible using EEM and Tcl.  Have a look at the script I did as part of my CiscoLive zero touch work for an example of how to interact with an HTTP server.
http://www.marcuscom.com/viewvc/viewvc.cgi/marcuscom/switch-ztp/trunk/eem/tm_sw_autoconf.tcl?revision=20181&view=markup
Hi Joseph,
I have curiosity,
Why are you executing this code?? Is this your principal code?? this is the first time that I see one TCL and EEM code.
Thanks for you help!!
Regards.
Not sure what you mean by "principal code," but I am running this to provide asset data over HTTP in order to facilitate zero-touch provisioning of switches.  The code pushes PID, serial number, and IOS version to an HTTP server that then replies with instructions on how to configure the switch.
