06-17-2016 07:06 AM
My Nexus 7k is seeming to generate false traps for my transceivers. The traps denote a change in the health of the transceiver. However, neither the logs nor when checking the relevant transceiver does there appear to be an issue with them. I have many similar type transceivers which do not generate the traps. The traps are generated at odd times and can be just two at a time or many. I have checked for bugs and cannot see any that might affect the software that is running on the 7k. I will try to re-seat and also replace if necessary but as there is no user impact being reported or errors on the interfaces being generated and as this is a live environment, I do not want to make any necessary changes that will impact the business. I am not very familiar with the SNMP traps so any input into why these are being generated would be greatly appreciated. Also the numbers that directly follow the interface slot/number (highlighted in bold), do they have any useful meaning? The trap information is as follows:
Hostname : 10.10.10.1
Description :
Date : 2016-06-16 14:07:50
EventName : CIFXCVRMONSTATUSCHANGENOTIF
TrapOid : enterprises.9.9.706.0.1
Category : STATUS EVENTS
Severity : NORMAL
Trap Message : This notification trap indicates the current status of the alarm and warning monitoring parameters for all the sensors based on the digital diagnostic monitoring information. This notification is generated whenever there is a change in the status of atleast one of the monitoring parameters of the sensors on the transceiver in an interface. Ethernet7/2 5 5 5 5 5 5 5 2 5 5 5
Notes :
An alert has been issued that requires your attention.
Description :
Date : 2016-06-16 14:12:50
Severity : NORMAL
Trap Message : This notification trap indicates the current status of the alarm and warning monitoring parameters for all the sensors based on the digital diagnostic monitoring information. This notification is generated whenever there is a change in the status of atleast one of the monitoring parameters of the sensors on the transceiver in an interface. Ethernet7/27 5 5 5 5 5 5 5 4 5 5 5
Notes :
We check these particular transceivers immediately after seeing the traps:
Nexus7k# sh int eth 7/2 transceiver details
Ethernet7/2
transceiver is present
type is 10Gbase-SR
name is CISCO-AVAGO
part number is SFBR-7700SDZ-CS2
revision is B5
serial number is AGD131633YD
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM2 fiber is 82 m
Link length supported for 62.5/125um fiber is 26 m
Link length supported for 50/125um OM3 fiber is 300 m
cisco id is --
cisco extended id number is 4
cisco part number is 10-2415-02
cisco product id is SFP-10G-SR
cisco vendor id is V02
number of lanes 1
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 30.37 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.31 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 5.71 mA 10.50 mA 2.50 mA 10.50 mA 2.50 mA
Tx Power -2.38 dBm 1.69 dBm -11.30 dBm -1.30 dBm -7.30 dBm
Rx Power -9.78 dBm 2.00 dBm -13.90 dBm -1.00 dBm -9.90 dBm
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
Nexus7k# sh int eth 7/27 transceiver details
Ethernet7/27
type is 10Gbase-SR
name is CISCO-FINISAR
part number is FTLX8571D3BCL-CS
revision is D
serial number is FNS14420A7E
cisco id is --
number of lanes 1
Temperature 31.40 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.30 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 7.42 mA 11.80 mA 4.00 mA 10.80 mA 5.00 mA
Tx Power -2.21 dBm 1.69 dBm -11.30 dBm -1.30 dBm -7.30 dBm
Rx Power -1.02 dBm 2.00 dBm -13.90 dBm -1.00 dBm -9.90 dBm
As you can see the diag info shows the transceivers to be operating within limits of the alarm or warning threshold.
The module details:
NAME: "Slot 7", DESCR: "1/10 Gbps Ethernet Module"
PID: N7K-F248XP-25E , VID: V01 , SN: JAF1801BGQS
The Chassis details:
Nexus7k# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.htm
l
Copyright (c) 2002-2015, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
BIOS: version 2.12.0
kickstart: version 6.2(14)
system: version 6.2(14)
BIOS compile time: 05/29/2013
kickstart image file is: bootflash:///n7000-s2-kickstart-npe.6.2.14.bin
kickstart compile time: 7/27/2015 9:00:00 [08/27/2015 23:28:02]
system image file is: bootflash:///n7000-s2-dk9-npe.6.2.14.bin
system compile time: 7/27/2015 9:00:00 [08/28/2015 01:32:40]
Hardware
cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor Module-2")
Intel(R) Xeon(R) CPU with 12224948 kB of memory.
Processor Board ID JAF1750BTEG
Device name: Nexus7k
slot0: 7989768 kB (expansion flash)
Kernel uptime is 68 day(s), 14 hour(s), 13 minute(s), 24 second(s)
Last reset
Reason: Unknown
System version:
Service:
plugin
Core Plugin, Ethernet Plugin
Kind Regards,
Clive Hodgetts
