fastethernet port showing down down
normandaniel09
Hi guys,
I have a port on my switch that always shows down.
#show interfaces fastEthernet 1/0/19
FastEthernet1/0/19 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 001e.f686.dd15 (bia 001e.f686.dd15)
  Description: IP Phone & PC Port
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 6w3d, output 00:10:24, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 15
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     11189035 packets input, 8414542539 bytes, 0 no buffer
     Received 103348 broadcasts (27165 multicasts)
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 27165 multicast, 0 pause input
Norman D.
Marvin Rhoads
Apparently whatever was once connected to it is either no longer connected to that port or was turned off. Do you have reason to believe it should be up?
Hello Norman
This is saying it even nothing is attached to that port or something physical is wrong -Please check your connections - cabling/sfp's/ ports.
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
