01-24-2013 10:22 PM
Hi guys,
I have a port on my switch that always shows down.
#show interfaces fastEthernet 1/0/19
FastEthernet1/0/19 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 001e.f686.dd15 (bia 001e.f686.dd15)
Description: IP Phone & PC Port
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 6w3d, output 00:10:24, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 15
Queueing strategy: fifo
Output queue: 0/40 (size/max)
11189035 packets input, 8414542539 bytes, 0 no buffer
Received 103348 broadcasts (27165 multicasts)
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 27165 multicast, 0 pause input
Norman D.
01-25-2013 06:43 AM
Apparently whatever was once connected to it is either no longer connected to that port or was turned off. Do you have reason to believe it should be up?
01-25-2013 05:14 PM
Hello Norman
This is saying it even nothing is attached to that port or something physical is wrong -Please check your connections - cabling/sfp's/ ports.
res
Paul
Please don't forget to rate this post if it has been helpful.
