Fault View CiscoWorks LMS 4.0.1
pefernandezc
Hello
I upgraded the LMS 4.0 with LMS 4.0.1 but now the events are removed of Fault View. The equipaments than I am monitoring are: ME-3600, ME-3800 and ASR 9000. This is a configuration problem or I have to update something else?. Thanks.
ngoldwat
Level 4
Level 4
Are you running a proxy? CSCtk47472
Is your server both forward & reverse resolvable? Under \CSCOpx\bin, do reverse and forward lookup using resolver.pl:
\CSCOpx\bin> perl resolver.pl
Are all of your services running?  Please open a command prompt and execute 'pdshow -brief'.
Perhaps DFM & DCR are out of sync.  You can try to unmanage/manage all devices in DFM in order to force it to sync again.
