Firewall ASA - Global Policy-map not being saved in Packet Tracer
yoveena
Hello Cisco Expert,
Hope you are doing good.
I am working on a project in Cisco Packet Tracer 8.1.1, and current running into an issue where I am unable to save the global policy of the 5506-X firewall [version 9.6(1)].
As per my requirement, I will need to inspect icmp and http.
I try to remove the global policy, recreate a new one with the same name and save the config.
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect http
inspect icmp
service-policy global_policy global
At first, it is working fine and I am able to reach my external server.
However, once I close the pkt file and reopen it, the global policy I created is overwritten by the default global policy of the firewall.
parameters
inspect ftp
inspect tftp
Is there any way to fix this?
Thanking you in advance and awaiting for a response.
Yoveena
12 Replies 12
 This can be a bug from your side. For me, the configuration remains after reload
parameters
inspect ftp
inspect tftp
policy-map global_policy2
inspect http
inspect icmp
ciscoasa#sh clock
*0:1:17.115 UTC Mon Mar 1 1993
ciscoasa#
Hi @Flavio Miranda,
I successfully added another policy map and was able to retrieve the configuration after reload but could not reach my external server.
I try to remove the existing service policy, add another another one and was able to reach my external server.
parameters
inspect ftp
inspect tftp
inspect http
inspect icmp
service-policy global_policy2 global
However, once I close the pkt file and reopen it, the global service policy I created is overwritten by the default global service policy of the firewall.
parameters
inspect ftp
inspect tftp
inspect http
inspect icmp
Is there any workaround to resolve this issue?
Yoveena
It did not happen to me so, I wonder if this can be a problem from your side only.  Can you share your PKT file and I can take  a look.
Hi @Flavio Miranda,
Please find attached the PKT file.
Awaiting for your response.
Yoveena
 The below configuration is on the firewall.
parameters
inspect ftp
inspect tftp
inspect http
inspect icmp
I can see it even after firewall reboot.
However, your firewall does not have any Access List allow traffic.  Is it because you are still working on it ?
Hi Flavio,
The issue I had previously regarding the global policy map has been resolved since I created a second policy map policy-map global_policy2 and added inspect icmp and inspect http. However, I couldn't ping my external server.
I then created a second service policy service-policy global_policy2 global. I saved the config and ping my external server. Both the  ping and http request were successful.
When I close my PKT file and reopen it, the service policy I created service-policy global_policy2 global is overwritten by the default service-policy global_policy global of the firewall.
Even without any Access-list, my internal hosts should be able to reach my external server. Nevertheless, from the external side there should be no access to my internal network due to the security-level.
Is there any workaround to save the service-policy global_policy2 global in my topology?
Yoveena
just to cover the basics: you did issue the 'wr mem' command ?
yoveena
Hello @Georg Pauwen,
Yes, I used the 'wr mem' command during the configuration. However, the issue still persists with the service-policy global_policy global.
what about:
copy running-config startup-config
I have also used the copy running-config startup-config command during the configuration. However, the issue remains the same.
Yoveena
Odd, I have the exact same problem. Nothing is saved.
Hi @Georg Pauwen,
Is this a bug in the Firewall 5506-X of cisco packet tracer?
Do you have any workaround that could help me to save these configurations or could you provide any alternative way?
Yoveena
