Cisco FTP Directory Probelm
Ali Hazim
Hi Everyone,
I'm having a problem when using FTP to backup my devices' config files, the problem is that I can't copy the config file to a certain directory within the FTP server, for example the following command won't work:
#copy nvram:startup-config ftp://x.x.x.x/dir1/dir2/dir3/"Config-File"
It will only accept the command in the following form:
the problem is that the above command won't save the file to the directory that I want, it will save it in the main directory.
Please note that I know if use the command (#copy nvram:startup-config ftp://x.x.x.x) and press enter, I can then specify the desired directory, but that won't help me because I won't to use kron to send the backup every day in all of my devices.
Also note that I've tried it on different devices and different IOS images and I got the same Result.
Thank You
5 Replies 5
balaji.bandi
Is that FTP have username and password ? or open for any one to upload Files.
If you like copy the file to below  folder - dir1/dir2/dir3/"Config-File"
user should have rights to write permission to write the file
or change the Root folder of FTP to dir1/dir2/dir3/"Config-File"
by the way what FTP Server, what you see the logs when the cisco router try to copy to folder -dir1/dir2/dir3/"Config-File"
BB
I have configured the FTP server with username and password using the commands (ip ftp username & ip ftp password).
When I try to copy the config file to the FTP server a log message will show up saying (permission denied) even though I made sure that the user has write permission (I also used it with FileZilla and I can write with it).
As an Example:
#copy nvram:startup-config ftp://192.168.165.46/home/HalaNOC/Cores/TEST
Address or name of remote host [192.168.165.46]?
Destination filename [home/HalaNOC/Cores/TEST]?
Writing home/HalaNOC/Cores/TEST
%Error opening ftp://192.168.165.46/home/HalaNOC/Cores/TEST (Permission denied)
(The device won't accept that above command because it's a "permission denied), but if I did it as bellow:
Destination filename [sw1]? /home/HalaNOC/Cores/TEST
Writing /home/HalaNOC/Cores/TEST !
7726 bytes copied in 0.052 secs (148577 bytes/sec)
(The device will accept it even though it's the same username and password)
- Check your ftp server's logs too , or use debugging mode . if supported. Then compare successful attempt versus failed attempt , in the ftp-server's logs
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
the user need to have rights all the way in the path, not just the folder
for each testing - make user home directory home/HalaNOC/Cores/TEST ( give all permission and test it)
by the way what FTP Server is this ?
BB
 Seems to me as a permission   problem. Do you have permission to write on those directories ?
