Flexible Flow in Cisco ASR1001-X version Version 15.5(3)S1a asr1001x-universalk9.03.16.01a.S.155-3.S1a-ext.SPA.b
maileh
I have trouble with my router cannot send the flow to the collector.
Here is my flow exporter status
ha-ir1#sh flow exporter FLOWEXPORT statistics
Flow Exporter FLOWEXPORT:
Packet send statistics (last cleared 16:55:21 ago):
Successfully sent: 12 (1848 bytes)
Reason not given: 75428 (89591904 bytes)
Client send statistics:
Client: Flow Monitor FLOW-IPv6
Records added: 1514279
- failed to send: 1514279
Bytes added: 87828182
- failed to send: 87828182
Client: Flow Monitor FLOW-IPv4
Records added: 0
Bytes added: 0
Client: Option options vrf-id-name-table
Records added: 24
- sent: 24
Bytes added: 864
- sent: 864
Here is my confiure for flexible flow
Flow Record
flow record v6_r1
match ipv6 traffic-class
match ipv6 protocol
match ipv6 source address
match ipv6 destination address
match transport source-port
match transport destination-port
match routing vrf input
match routing vrf output
match mpls label 1 details
match mpls label 2 details
collect counter bytes long
collect counter packets long
Flow Moitor
flow monitor FLOW-IPv6
exporter FLOWEXPORT
record v6_r1
Flow Exporter
description Send Netflow to Collector
destination 10.254.36.152 vrf Mgmt-intf
source Loopback50
transport udp 9995
option vrf-table
management interface
interface Loopback50
description Flow Exporter
vrf forwarding Mgmt-intf
ip address 10.254.32.192 255.255.255.255
###########Flow Interface
interface GigabitEthernet0/0/4.805
description ***IPV6 Peer ****
encapsulation dot1Q ABC
ipv6 flow monitor FLOW-IPv6 input
ipv6 flow monitor FLOW-IPv6 output
ipv6 address Prefix
ipv6 enable
ipv6 traffic-filter IPV6-Filter
end
##########3Ping to my Collector from my Exporter Source Interface
ha-ir1#ping vrf Mgmt-intf 10.254.36.152 source lo50
Sending 5, 100-byte ICMP Echos to 10.254.36.152, timeout is 2 seconds:
Packet sent with a source address of 10.254.32.192
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
I do not know where else i can look for help ..... appreciate anyone with links or suggesstion...
0 Replies 0
