Flexible NetFlow Causing DNS Issues
bkozan
Community Member
I recently deployed Flexible NetFlow on some of my 2821 routers (Version 12.4(9)T3). This was required because I needed to export my flow records via an IPSEC / GRE tunnel, and traditional NetFlow wouldn't encapsulate within the IPSEC tunnel. So I migrated to Flexible NetFlow. As soon as I did this all DNS queries from hosts on the inside network began to fail. has anyone seen this issue? Is there a fix? Currently I have simply turned off NetFlow collection on the routers in question.
Config:
flow exporter StoFlowExporter
destination 10.x.x.x
source GigabitEthernet0/0.461
transport udp 2055
flow monitor StoNetFlow
record netflow ipv4 original-input
interface GigabitEthernet0/0.461
description LAN
encapsulation dot1Q 461
ip address 10.x.x.x 255.255.255.0
ip access-group LAN_Outbound in
ip flow monitor StoNetFlow input
ip nat inside
ip virtual-reassembly
0 Replies 0
