03-07-2018 04:48 AM - edited 03-01-2019 06:26 PM
I am testing the following Flexible Netflow configuration on one of our ASR1001-X in the lab.
The router is running 3.14.0S:
flow record ipv4-netflow-record match ipv4 protocol match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port collect counter bytes collect counter packets ! ! flow exporter ipv4-netflow-exporter destination <collector_IP_address> vrf MGMT source GigabitEthernet0/0/2 transport udp 2055 export-protocol netflow-v5 ! ! flow monitor ipv4-netflow-monitor exporter ipv4-netflow-exporter record ipv4-netflow-record ! sampler ipv4-netflow-sampler mode deterministic 1 out-of 1024 ! interface GigabitEthernet0/0/4 [..] ip flow monitor ipv4-netflow-monitor input ip flow monitor ipv4-netflow-monitor output [..] !
The flows are collected, however, they are not exported to the collector:
lab#sh flow monitor ipv4-netflow-monitor cache
Cache type: Normal (Platform cache)
Cache size: 200000
Current entries: 31063
High Watermark: 67037
Flows added: 11665907
Flows aged: 11601943
- Active timeout ( 1800 secs) 1097
- Inactive timeout ( 15 secs) 11600846
IPV4 SRC ADDR IPV4 DST ADDR TRNS SRC PORT TRNS DST PORT IP PROT bytes pkts
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy 11393 443 6 156 3
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy 443 23502 6 2651 4
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy 0 0 1 36 1
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy 18155 80 6 1284 27
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy 443 9313 6 3380 20
lab#sh flow exporter name ipv4-netflow-exporter statistics
Flow Exporter ipv4-netflow-exporter:
Packet send statistics (last cleared 01:10:47 ago):
Successfully sent: 0 (0 bytes)
Client send statistics:
Client: Flow Monitor ipv4-netflow-monitor
Records added: 0
Bytes added: 0
Connectivity between exporter and collector is ok. Also, port 2055/UDP on the server is open.
Any hints as to why the flows are not exported even though they are collected?
BR,
Kostas
Solved! Go to Solution.
03-07-2018 07:08 AM
03-07-2018 07:08 AM
