Flexible Netflow multiple exporters
mpidoux_upc
Hello everyone,
I configured Flexible Netflow on a Cisco ASR-920-4SZ-A, with IOS asr920-universalk9_npe.03.18.03.SP.156-2.SP3
The first exporter is working well but the second one is not working, no data sent.
If I remove the first exporter, it's working well. Netflow monitoring server is working well, it receives data from another interface.
Is there something wrong in my configuration ? Is it normal or a bug ? I read in the official doc it was possible to configure multiple exporters.
flow record NETFLOW-RECORD
 match interface input
 match interface output
 match ipv4 source address
 match ipv4 destination address
 match ipv4 protocol
 match transport source-port
 match transport destination-port
 match ipv4 tos
 collect counter packets
 collect counter bytes
flow exporter NETFLOW-EXPORT-1
 destination 10.100.1.1
 source GigabitEthernet0/0/0
 transport udp 2055
 template data timeout 60
flow exporter NETFLOW-EXPORT-2
 destination 10.200.1.1
 transport udp 2055
flow monitor NETFLOW-MONITOR
 cache timeout inactive 20
 cache timeout active 60
interface GigabitEthernet0/0/0
 ip flow monitor NETFLOW-MONITOR input
 ip flow monitor NETFLOW-MONITOR output
router1#show flow exporter statistics
Load for five secs: 3%/0%; one minute: 2%; five minutes: 2%
Time source is NTP, 10:18:10.263 CET Tue Feb 13 2018
Flow Exporter NETFLOW-EXPORT-1:
  Packet send statistics (last cleared 3w4d ago):
    Successfully sent:         9063533               (11714767342 bytes)
  Client send statistics:
    Client: Flow Monitor NETFLOW-MONITOR
      Records added:           369166839
        - sent:                369166839
      Bytes added:             11112133640
        - sent:                11112133640
Flow Exporter NETFLOW-EXPORT-2:
  Packet send statistics (last cleared 1w0d ago):
    Successfully sent:         45334                 (5077408 bytes)
      Records added:           0
      Bytes added:             0
Thanks in advance for your help.
theamberlion
I would try to configure exporters with different configurations. For example, use different ports and source-interfaces (maybe loopback ones).
Give it a try.
Still the same result, no data sent to the client.
