Hello, I am encountering a problem with flexible netflow on a cisco Catalyst 3850. The packets are not exported to the collector (I ping the collector well). Morevover, the packets not exported are in the cache. I can see that, when I type the command "show flow monitor statistics" :
Cache type: Normal (Platform cache)
Cache size: 10000 Current entries: 2096
Flows added: 2096
Flows aged: 0
My configuration :
flow record goelastic_input
match ipv4 destination address
match ipv4 source address
match transport source-port
match transport destination-port
match ipv4 protocol
match ipv4 tos
match ipv4 ttl
match interface input
match flow direction
match datalink vlan input
collect counter bytes long
collect counter packets long
flow exporter exp_goelastic_input
destination 192.168.1.100
source Loopback0
transport udp 2055
flow monitor ipv4_netflow_input
cache timeout active 60
Has anyone encountered this problem ?
