Flexible Netflow v9 | Flow Identification (5 Tuple)
tschafferx
Hello Cisco Community,
I read that the minimum fields to determine a flow in Netflow is the 5 Tuple (SA,DA,SP,DP,PR).
Now I read about flexibleNetFlow and that there is a possibility to define KeyFields. (IP (Source or Destination), Mask (Source or Destination)...
Here comes my question:
If the mininimum required fields are the 5 Tuple, then how can I possibly identify a flow that just matches the key field Source IP Address?
Thank you in advance.
0 Replies 0
