FortiGate MIB Compatibility with Prime Infrastructure
Tom Cecil
I have a Cisco Prime Infrastructure deployment that I would like to monitor various third-party devices. I have successfully discovered my FortiGate 60D device, but it has no monitoring functionality.
I am trying to create a custom SNMP polling template to deploy to the device and I'm wondering is the FortiGate MIB is even supported by PI? If so, which SNMP MIB do you select when creating a new template?
Tom Cecil
The FortiGate SNMP page on the FortiGate Web GUI links two MIB downloads:
  1. FORTINET-FORTIGATE-MIB
  2. FORTINET-CORE-MIB
I have successfully uploaded the FORTINET-CORE-MIB file to the Prime Infrastructure MIB list and I am able to successfully apply that MIB to a template and the template to a dashlet, which outputs data. The issue is when I try to upload the FORTINET-FORTIGATE-MIB file, it produces an error message showing:
Tom
Need Help. Facing same problem here...
