FQDN Hostname for Syslog
InfoSecKeks
Hi All,
I am able to set a logging hostname in my Cisco routers/switches (3xxx, 4xxx), however, this FQDN appears to be instantly resolved (translated) to the IP address sitting behind the FQDN.
When I look at the running config, the logging host is no longer the hostname, but rather the IP address that was resolved when the logging host config line was entered.
I want to ensure that syslog is sent to this FQDN rather than IP address due to DNS redundancy/fail-over configuration we have in place for these syslog collectors.
Is there a way to do this?
Example below:
SWITCH(config)#logging host hostname.domain.com
Translating "hostname.domain.com"...domain server (1.2.3.4) [OK]
SWITCH(config)#
SWITCH(config)#exit
SWITCH#show run | i logging
no logging message-counter syslog
logging buffered 32000 informational
no logging console
no logging monitor
  logging enable
  logging size 1000
logging trap notifications
logging origin-id hostname
logging source-interface Vlan155
logging host 10.10.10.20 <--This is the current resolved IP of hostname.domain.com
 - Well , what you can do , is if you have multiple syslog servers behind a FQDN, is to list then all 'ip-wise' in the running-config.
M.
7 Replies 7
marce1000
 - Not possible (what you want) ; probably because  in a networking environment there could be circumstances that the DNS is not reachable and then the switch wants to be able to keep logging (it is designed) that way.
M.
That makes sense. That's unfortunate though... Thanks for the reply.
M.
Let's say I have 4 syslog servers configured. If I configure syslog with FQDN it instantly translates.
If I list all four servers syslog will be send to 4 servers instead of the "active" one.
Am I right?
Thank you.
@ziqex Yes , but the switch won't be able to determine the active one with FQDN if it also translates to 4 addresses (UDP is a connectionless transport)  ; anyway the switch can not use that methodology and it is also a security precaution to avoid sensitive information arriving at the wrong place ,
 M.
Thank you for your reply.
I guess it is the same with Cisco routers.
 - @ziqex   wrote : I guess it is the same with Cisco routers.
                             Yes , it is ,
 M.
