FWSM, allowing remote management.
andrea.meconi
Level 2
Level 2
Hello.
I'm using a FWSM with multiple contexts. One of these contexts serves CiscoWorks LMS.
I need to manage all others contexts on outside interface using insecure protocols, like SNMP or Telnet.
I have tried to setup a VPN L2L connection between contexts without success.
Any idea?
Thanks.
Andrea
Marvin Rhoads
The FWSM doesn't support VPNs.
You'll need to create rules (access lists) allowing communications between the tiers (contexts) for LMS to reach them via the desired protocols.
Hello Marvin and many thanks for your help.
The FWSM supports IPSec for management access. You can configure site to site or remote access VPN.
I have configured a remote access VPN, and using Cisco VPN client I can manage a context using Telnet on outside interface.
However, in case of the FWSM, the only address available on the module end of the tunnel is the interface itself.
This is because a site to site VPN doesn't work, using NAT also.
Regards.
Andrea
