GUI start using Integration Utility 1.7.1
lomonaco
Hi Everyone,
I have one HPOV Server (7.51) using Solaris 9 and one CW Server (LMS 3.0.1 Update Dec 07 using too Solaris 9 in another station.
I installed the Integration Utility 1.7.1 in HPOV, but when I try to start it from my desktop (using Reflector X-Windows) I can't see the GUI interface...
/opt/CSCOpx/bin/ xhosts .
/opt/CSCOpx/bin# sh nmic.sh
Launching Change Integration Options...
xclock, xterm, run as expected...
Is necessary to run the Integration Utility directly from the server monitor/keyboard?
Thanks in Advanced
Andre Lomonaco
Joe Clarke
We only tested with nmic running locally on the attached display. However, I have run it over to another native X11 display (on OS X and FreeBSD) using ssh X11 forwarding.
Java does use some fonts that may not be available in Reflection, so that may be part of the problem. You may have to tweak some settings to get a Java application to show up properly.
