04-10-2013 08:08 PM
Anyone have any ideas on monitoring H.323? I've got a 3925 running15.1(3)T with 9 PRI's. Because of our volume, syslogging is not the desired solution. We want something that we can potentially graph over an 8 hour period, so while the RTMT is accurate, either it won't store the data for 8 hours, or we aren't using it correctly (plus, mgmt may want access to the stats/graphs, and we're not keen on granting them access). So far, we've used:
ccvpIcmRtActiveH323CallLegs (1.3.6.1.4.1.9.9.590.1.6.4.1.3)
cdspActiveChannels (1.3.6.1.4.1.9.9.86.1.2.1.1.8)
cpmDS0ConfigFunction (1.3.6.1.4.1.9.10.19.1.5.2.1.7)
None of these seem to accurately portray utilization. cdspActiveChannels seems to get the closest, so perhaps I have to tweak it a little bit, but so far, nothing accurate.
Suggestions?
Thanks!
04-10-2013 08:46 PM
Sorry...don't know via SNMP. Don't know if this would help but if using CUCM Call Manager, this solution would report your usage/utilization of your PRI's/Trunks/Route Groups via CDR call history info:
04-11-2013 08:19 AM
This looks great! Where are you running this from?
04-11-2013 08:38 AM
Hi there -
It's a web-based, third-party app, Variphy Insight. Made by a Cisco Dev partner. Ask online for a free, full enterprise trial from them, mention the Cisco Support Forum, and get an extended 90 license key for the trial instead of the usual 15 days.
