hardware address
Nuno Castro
Community Member
Hello all;
I have an Access Point enginius 2610, connected directly to cisco 877 router Port F2. Seems that the router isn't recognizing the mac of the Access Point, and is always putting the port in down state.
Access point:
IP: 10.0.0.2 Mac:0002.6f57.8e14
Here is some commands:
sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.0.1                -   0015.6388.39d3  ARPA   Vlan2
Internet  10.0.0.2                0   Incomplete      ARPA
Internet  10.0.0.3               10   000e.2ece.63c9  ARPA   Vlan2
Internet  192.168.1.1             -   0015.6388.39d3  ARPA   Vlan1
Internet  192.168.1.68            1   e89a.8ff6.e262  ARPA   Vlan1
Internet  192.168.1.253           3   0021.918d.7d6b  ARPA   Vlan1
Internet  192.168.1.254           6   9c97.268e.ed14  ARPA   Vlan1
sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  down                down
FastEthernet3              unassigned      YES unset  up                    up
NVI0                       unassigned      YES unset  administratively down down
Vlan1                      192.168.1.1     YES NVRAM  up                    up
Vlan2                      10.0.0.1        YES NVRAM  up                    up
term mon
*Jul  7 03:57:57.027: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
*Jul  7 03:58:00.140: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
*Jul  7 03:58:06.577: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
*Jul  7 03:58:11.002: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
*Jul  7 03:58:13.487: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
*Jul  7 03:58:19.620: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
*Jul  7 03:58:22.569: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
How can i solve this?
regards;
5 Replies 5
Mark Elsen
 - Besides 'term mon' could you also have a look at the complete logs of the router as in
# show  loggging
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
sh logging
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 108 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  disabled, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
    Trap logging: level informational, 108 message lines logged
lcastro#sh arp
Internet 10.0.0.4 0 Incomplete ARPA
Internet 10.0.0.12 0 e0ca.9470.d200 ARPA Vlan2
Internet 10.0.0.14 1 b452.7e94.3baf ARPA Vlan2
Internet 192.168.1.254 1 9c97.268e.ed14 ARPA Vlan1
sh ip int brief
FastEthernet2              unassigned      YES unset  up                    up
Virtual-Access1            unassigned      YES unset  down                  down
Virtual-Template1          192.168.1.1     YES TFTP   down                  down
The original post had this line
If FastEth2 is down then that explains why the router is not recognizing the mac of the access point.
The more recent post has this line
If FastEth2 is now up then perhaps the router now recognizes the connection of the access point? Other than show arp how are you checking for the connection of the access point?
Would you post the configuration of interface FastEth2?
Rick
Rick
Helo;
Thanks a lot Richard. I have solved the problem, adding
 duplex full
 speed 10
In port configuration.
Thank you for posting back to the forum to let us know that you solved the problem by changing port parameters for speed and duplex. I am glad that you were able to get the problem worked out.
Rick
Rick
