Hardware identification
100012550
I have numerous CISCO hardware equipment in my infrastructure, I have all the serial numbers for the Chassis, however I cannot find a way to check if they can still be supported through our Partner supplier.
Is there as reverse Serial Tracker tool where I can:
  1. Identify the CISCO Hardware (model Type etc.)
  2. Still has support (IoS etc.)
  3. EoL or EoS.
  4. Time to replace with the latest equivalent hardware.
Thanks in Advance.
jossabor
I guess what you are looking is something like the CAA:
http://www.cisco.com/c/en/us/products/cloud-systems-management/active-advisor/index.html
bastiaankok
You can find the info based on serial number in the Cisco Service Centre: (if your Cisco CCO-id have access to this tool)
1.  Go to the Service Contract Centre:  http://www.cisco.com/warp/public/437/scc/index.html
2.  Click "Launch Tool"
3.  A window should hopefully pop up. (if you have acces to this tool). In the search bar, choose "Serial Number".fill in the serial number en click "go".
Mark Elsen
 - Device coverage checker might be usefull too :
                      https://cway.cisco.com/sncheck/
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
