having problem with my cisco857w , please help
faltas_a
Hi Guys
I have cisco 857w, i managed to configure it and I use it as wireless modem router, I have PC, VOIP adaptor and 7 wireless devices connected. i can access the internet from all of them no problem ,but the issue I have is I can't ping any wireless laptops from any other wireless. the reason I need to do that is because i can't install my wireless printer on my wireless laptops. but also I have to mention the PC connected through one of the FastEthernet port of the router I can print to the printer wirelessly.  this drive me crazy. I attached my config. thanks for you help
David
luijimen
Hi David,
I believe it would be best that you post this thread in the Wireless and Mobility community
https://supportforums.cisco.com/community/netpro/wireless-mobility
You should have better chances there. Good luck!
Luis
Thanks Luis, but how do I change and post it as your recommend?
any more help guys?
