snmp mib OID ASA 5540
Issa NDIAYE
I m using network monitoring tool WhatsupGold,
now i have problem with SNMP MIB on ASA 5540, i cant' monitor CPU and DISK,
What is the OID which allow to monitor CPU and disk on the ASA 5540?
Best Regards
Pradeep Vaka
Hi Issa,
For CPU you can poll the following OIDs
.1.3.6.1.4.1.9.9.109.1.1.1.1.3 cpmCPUTotal5sec
.1.3.6.1.4.1.9.9.109.1.1.1.1.4
cpmCPUTotal1min
.1.3.6.1.4.1.9.9.109.1.1.1.1.5
cpmCPUTotal5min
What are you refering to disk?
If its memory usage you can use ciscoMemoryPoolMIB
Here are all the supported mibs for ASA
ftp://ftp.cisco.com/pub/mibs/supportlists/asa/asa-supportlist.html
Sonatel:Scan antiviral effectue (2)
Thanks you ! it’s ok now
The memory is ok
Best regards!
De : pvaka
Envoyé : lundi 12 septembre 2011 07:04
À : Issa NDIAYE
Objet : - Re: snmp mib OID ASA 5540
Sonatel:Scan antiviral effectue (1)
Cisco Support Community<>
created by Pradeep Vaka<> in Network Management - View the full discussion<>
OK great,
Probably we can close this post since the information is helpful
Hello pvaka,
Yes you can close it
Best regards…!
De : pvaka
Envoyé : vendredi 16 septembre 2011 06:43
À : Issa NDIAYE
