Help connecting these networks
DiogoKh
Hello! So i made this, this are 3 networks that are currently working through dhcp. But i need to connect them and i dont seem to be able to. Could anyone share some knowledge please?
6 Replies 6
M02@rt37
Hello @DiogoKh
Connect routers each other.
Add static routes on each router in order to route each LAN/Networks.
Best regards
I have been trying that but im not sure im doing it correctly. The wireless router doesn't seem to have an option to do static routing, And the other two i have them set up like this.
Thank you for the response, any help is very apreciated!
@DiogoKh
On the 2 Routers on the right, dont use serial links. Start by traditional FastEthernet or GigabitEthernet interface.
Best regards
Got to this point but i think the static routing its what keeping my pcs from talking to others from the other networks. Cant seem to figure this out.
DiogoKh
My static routing looks like this. I cant figure out whats wrong with it. My pcs from the middle network will not connect to the ones on the right even tough the routing seems to be okay. I´ve been at this for almost 8 hours now,
@DiogoKh
Is it possible to share your PT projet here in a zip file ? I could assist you.
Best regards
