Help Interpreting Netflow Output
Hello Community,
I have been evaluating a script that allows you to see top talkers in realtime.
For an explanation of the script please see attached.
I'm having a problem interpreting the output. For example, the following appears five times with different AvgBits/s
SRCIP           DSTIP           APPLICATION   PROT   DIRN Start  AvgBit/s AvgPkt/s
194.75.202.233  80.229.108.65   0/0           ESP    IN   07:28    111K     40
Would the correct interpretation be, 'at 07:28am, the AvgBits/s was 111K?
If so I ran the script again and a few hours later and I got the following:
194.75.202.233  80.229.108.65   0/0           ESP    IN   07:28   2.69M    296
You will notice that the time is the same, however the AvgBits/s is now 2.69M. I don't understand how the time remains the same, even though I ran the script match later and the Mb is 2.69M??
I have also attached a sample showing the following addresses:
10.50.96.30     10.45.156.82    445-microsoft.
In the above sample, can someone explain why AvgBit/s was 1.95M, and later it was 239K?
Cheers
Carlton
Joe Clarke
This is a flow.  The flow can last a long time, as it appears to be doing in this case.  Given that this is VPN traffic, that makes sense.  When you first ran the script, the average was 111Kbps, but later in the day (likely after the user had cranked much more traffic through the VPN) the average was 2.69M.
Averages grow and shrink depending on time and the amount of traffic.  If an average goes down, it means for the life of that flow, the traffic rate decreased.  In the beginning it may have been high, but over time, less traffic was sent.
8 Replies 8
Joe Clarke
Joseph thanks again for responding.
I have just one more question (I think :-) related to this issue.
I ran the script again at 13:17. From the output shown in the attached would it correct to say that all the flows shown, apart from:
194.75.202.233  80.229.108.65   0/0           ESP    IN   09:03
80.229.108.65   194.75.202.233  0/0           ESP    OUT  09:03
started at 13:17, and there weren't any flows that have been running before 13:17?
Cheers
Carlton
Thanks responding,
Can you tell me why the time, 07:28am is the same for 111K as it is for 2.69M? Even when I ran the script when I got 2.69M it was 13:00 If I run the script at, say 13:00 shouldn't the script show that time?
Cheers
The start time shown is the start of the flow, not the script.  This was a long-running flow.
Joseph,
Just one more question to clarify.
If I ran the script and I saw the following flow
194.75.202.233  80.229.108.65   0/0           ESP    IN   09:03    432K    100
And then I ran the script 15mins later and I saw the following flow:
194.75.202.233  80.229.108.65   0/0           ESP    IN   09:13    432K    100
Does that mean that between 09:03 and 09:12:59 the flow stopped and started again at 09:13?
Cheers
Carlton
It does look to be the case.  It was likely purged from the cache, then started up again.
Thanks again Joesph for that.
I wonder if you could shed some light on the following:
I ran the following command twice
show flow monitor FlowMonitor1 cache sort highest counter packets
In the first instance I got the following:
10.50.131.34     10.45.69.224              3009            161  Tu0                        17  Gi0/1.10              Input             107           1  15:51:32.580
In the second instance
10.50.131.34     10.45.69.224              3009            161  Tu0                        17  Gi0/1.10              Input             107           1  15:52:02.864
(please see attachment for better clarification)
Can you explain what is meant by 'time first'? If it means the time the first flow was recorded was 15:51:32.580 what does 15:52:02.864 time represent?
Thanks mate
This refers to the time the first packet in the flow was seen.  So you're looking at two different flows in this output.  Both appear to be SNMP, and likely just timing out of your cache between executions of the show flow monitor command.
