Help Needed
uzma85222
Community Member
I need some help on setting up a network. I have a desktop in my bedroom and want to connect a laptop downstairs. I need the laptop to be able to access the Internet. I have ordered a 5 port home router, but I am not aware of what types of cables I will need to use to connect the PC and laptop to the router and then the router to the Internet cable.
Please can anyone help me.
Uzma
2 Accepted Solutions
David Stanford
Most likely you'll just need Cat 5 ethernet cables to connect the PC/Laptop to the laptop. You will prob also connect the cable modem via ethernet to the router as well.
The router is going to need a configuration whether it's basic IP addressing, NAT, etc...It depends on what type of router you have as well.
David Stanford
Do i need to do any configuration on the router?
