help please - i think my DNS is broken
KEVIN MCCOY
DNS issue
so i am new to DNS, here is my problem, we have cisco umbrella forwarders on all our DNS servers
we have a marketing site hosted, externally the site works perfect however lately internally when we hit the url we get page cannot be displayed, the fix is to go to our DNS servers and clear cache which works for about 30 minutes then it breaks again
marce1000
 - Difficult to tell, in a first debugging step remove Umbrella from the DNS setup and start using the DNS servers from the  ISP. Check whether the problem then remains in place or not.
M.
CSCO11304974
Command prompt
#Sh ip config
Ping the primary DNS and Secondary DNS
Both DNS ping means there is no issue with ISP , not pinging means issue with ISP.
Praveen.N
pieterh
please collect some more information
1) if the site works what IP address is resolved?
2) if it does not work what IP addres is in the cache?
3) what is the SOA (primary DNS) of this domain?
4) where comes the timeout of 30 min from?
    (it may be this is the TTL of the dns-record that is too short)
looks like it was an issue on Cisco Umbrella side
Mash Sarband (Umbrella)
Nov 16, 14:12 PST
Anyone that used us as a DNS resolver. We will provide you with more infromation after we receive the RCA.
Mash Sarband
Regional Technical Support Manager (US west)
Cisco Umbrella
Nov 16, 14:07 PST
Thanks Mash, is this affecting all Cisco Umbrella customers or only a particular set?
-------- Original message --------
Nov 16, 14:05 PST
We have asked for a Root Cause Analysis from our engineers and will update you as soon as we hear back.
Best regards,
Mash Sarband
Cisco Umbrella
