Help with EEM script emailing server
Mark Malone
Hi i have wriiteen an EEM script basic enough but contains a lot of lines for data collection which work
What i want the script to do is
1 when BGP fails collects all commands  and dump them into flash in TXT file (this works)
2 When BGP comes backup wait 5 minutes for everything to settle then email me the file in flash too that was just generated (This doesnt work)
3 Just keep the latest copy in flash only
Now No 1 is working fine file gets dumped to flash
 32  -rw-            65898   Sep 5 2017 12:09:20 +00:00  BGP_IWAN_FAIL_NOTIFICATION_AUTO_LOG_COLLECTOR.txt
But i cant get the file to email to me even though i can ping the email server from the router when the BGP is backup
Once this is fully working i plan to convert it to TCL using i think Joes tool so theres less config on the router , were running thousands of lines per device so anything i can keep off it the better  ........https://www.marcuscom.com/convert_applet/
Here is exactly what i have , i have left out all the action lines that just collect config as that works its the EMAIL but not working right
I have omitted large part of actions as there just collecting commands 0.6 - 6.7
Im obviously doing something wrong with second syslog match as it doesnt even appear in my running config , so how do i match it when it comes back up and get ot to email
event manager applet BGP_IWAN_FAIL_NOTIFICATION_AUTO_LOG_COLLECTOR
 event syslog pattern ".*%BGP-5-ADJCHANGE:.*"
 action 0.1  info type routername
 action 0.2     cli command "enable"
 action 0.3     cli command "del /force bootflash:BGP_IWAN_FAIL_NOTIFICATION_AUTO_LOG_COLLECTOR.txt"
 action 0.5     cli command "trace 172.x.x.x num | append
 action 6.8     cli command "end"
 action 6.9 wait 300
 action 7.0 mail to "netws@gggg.com" from "mmalone@gggg.com" server "172.x.x.x" subject "BGP/IWAN Failed Information Automatically Collected Emailed And Attached To BootFlash" body "$results"
 action 7.1     cli "end"
 Also it im hogging the sessions too even though i put the end statement in , i locked myself out temmporarai;luy as all the lines were used
 %HA_EM-3-FMPD_ERROR: Error executing applet BGP_IWAN_FAIL_NOTIFICATION_AUTO_LOG_COLLECTOR statement 0.2
388677: Sep  5 12:07:02.615 UTC: %HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: 'Embedded Event Manager' detected the 'fatal' condition 'no tty lines available, minimum of 2 required by EEM'
388678: Sep  5 12:07:02.615 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet BGP_IWAN_FAIL_NOTIFICATION_AUTO_LOG_COLLECTOR statement 0.2
Thanks for any tips
5 Replies 5
Joe Clarke
EEM policies have a default max runtime of 20 seconds.  Therefore, waiting 300 isn't going to work without increasing that timer.  But that is not the right way to do what you want.
Have a read through How To Introduce Large Delays In EEM Policies .  This will give you a solution for adding your hold down timer.
Thanks Joe looking at it now
Hi Joe
are you not allowed have 2 sysliog matches in the same script , the syntax is there but whenever i add it to the script it doesnt show in running config even though it takes the commands
And can you use the event timer countdown like i have or does it have to be nestled like the link you sent me
no event manager applet BGP_IWAN_FAIL_NOTIFICATION_AUTO_LOG_COLLECTOR
 action 0.5     cli command "trace 172.22.160.3 num | append
 action 6.9     cli command "event timer countdown time 300"
 action 7.0 mail to .....................................................
You need to create a nested applet.  What you're doing here is essentially overwriting the initial applet's event.  Pay close attention to the syntax in the article for adding the delay.  You need to wrap the "event" command in a CLI command.
If you want to add multiple events in a single policy, then you need to use the tag syntax:
event tag syslog1 syslog ...
event tag syslog2 syslog ...
trigger
 correlate event syslog1 or event syslog2
Ok thank you
