Help with school project
rbowenjr
Community Member
I need help figuring out what is going wrong. I am only worried about the Honolulu network. I have 5 vlans setup. I also have 2 of them being given addresses via DHCP on the router. For some reason I cannot reach my servers or my printers though. I am also putting a link to the pkt file I am working. https://drive.google.com/file/d/1PHbuggEtOCTlassF1oe6YLaYfdI0yALK/view?usp=sharing
mvsheik123
Level 11
Level 11
Please share network block diagram and router/switch config so one of the members can help you with this.
MS
I have edited the original post to include everything that should be needed now.
Assuming all vlans/IPs correct, can you try by remvong port-security' from trunk ports?
MS
