Showing results forĀ
Search instead forĀ
Did you mean:Ā
Hi All,pls help in removing banner message from cisco 1900 router
itsecurity mk
message is: banner exec ^C % Password expiration warning. ----------------------------------------------------------------------- Cisco Configuration Professional (Cisco CP) is installed on this device and it provides the default username "cisco" for  one-time use. If you have already used the username "cisco" to login to the router and your IOS image supports the "one-time" user option, then this username has already expired. You will not be able to login to the router with this username after you exi this session. It is strongly suggested that you create a new username with a privilege lev of 15 using the following command. username
privilege 15 secret 0
Replace
and
with the username and password you want to Dears,           Recently i purchased new cisco 1900 series router,but unable to remove the banner msg ----------------------------------------------------------------------- ^C banner login ^C ----------------------------------------------------------------------- Cisco Configuration Professional (Cisco CP) is installed on this device. This feature requires the one-time use of the username "cisco" with the password "cisco". These default credentials have a privilege level of 15. YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN CREDENTIALS Here are the Cisco IOS commands. username
no username cisco Replace
and
with the username and password you want to use. IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF. For more information about Cisco CP please follow the instructions in the QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp ----------------------------------------------------------------------- ^C !
0 Replies 0
