high cpu utilization due to java
mia.miraples
Community Member
my Ciscoworks LMS 2.5 was experiencing high CPU load. Everytime i open the CW application CPU instantly increases to around 90%.
Hope you can help me resolve this issue.
Below are the data from the server:
PID USERNAME SIZE RSS STATE PRI NICE TIME CPU PROCESS
>1503 casuser 842M 176M cpu0 0 10 573:57:09 92% java/213
>1466 casuser 750M 479M sleep 59 0 71:23:22 4.3% sm_server
>1487 casuser 138M 133M sleep 59 0 53:01:50 1.8% dbsrv9/33
>1467 casuser 43M 34M sleep 59 0 4:23:16 0.7% dbsrv9/33
>25107 fpi 4744K 4496K cpu1 59 0 0:00:00 0.1% prstat/1
>278 root 3904K 1648K sleep 59 0 0:25:25 0.1% syslogd/1
>1489 casuser 118M 71M sleep 59 0 1:41:16 0.0% cwjava/39
>1737 casuser 61M 15M sleep 59 0 0:14:44 0.0% cwjava/53
>1322 casuser 16M 9480K sleep 59 0 0:17:55 0.0% dbsrv9/33
>594 root 63M 9752K sleep 29 10 0:27:22 0.0% java/24
>1850 casuser 362M 95M sleep 29 10 0:08:18 0.0% cwjava/28
>1768 casuser 43M 8608K sleep 59 0 0:00:41 0.0% cwjava/35
>1484 casuser 16M 11M sleep 59 0 0:19:19 0.0% dbsrv9/33
>1451 casuser 35M 2504K sleep 59 0 0:00:12 0.0% cwjava/10
>1384 casuser 23M 9680K sleep 59 0 0:06:17 0.0% dbsrv9/33
>1074 root 3816K 2856K sleep 59 0 0:08:59 0.0% mibiisa/7
>1321 casuser 163M 34M sleep 29 10 0:04:32 0.0% cwjava/16
>1753 casuser 60M 18M sleep 59 0 1:40:27 0.0% cwjava/21
>1424 casuser 230M 18M sleep 59 0 0:30:18 0.0% dbsrv9/63
>298 root 2304K 1008K sleep 59 0 0:00:00 0.0% cron/1
>509 root 1800K 696K sleep 59 0 0:00:00 0.0% powerd/2
>501 root 58M 8688K sleep 29 10 0:03:50 0.0% java/19
>bash-2.05$ vmstat -S
> kthr memory page disk faults cpu
> r b w swap free si so pi po fr de sr m1 m1 s0 s1 in sy cs us sy id
> 1 0 0 6073120 60336 0 0 23 21 26 0 25 0 0 0 0 1029 1563 2871 52 2 46
>bash-2.05$ sar -u 5 1
>SunOS SVR-MGONMS-01 5.9 Generic_118558-11 sun4us 09/15/2006
>09:13:43 %usr %sys %wio %idle
>09:13:48 99 1 0 0
David Stanford
Can you also get the output of the pdshow command at the same time this is occuring? Then you can match the PID from above with a PID in pdshow to see which LMS process specifically is causing this problem.
