Path Analysis and interface Multilink
ROMAN TOMASEK
Level 6
Level 6
I tried to use Path Analysis for trace traffic from IP address of the end user PC (it is in UT database) and the Cisco router with IP address on the interface Multilink. The Cisco router is in the Campus database, but with management IP address. When I used Detailed device report - the IP address of interface multilink is seen. So Path Analysis has problem with this IP address. The trace is ended with message unknown IP address. What is the solution of this problem? Thank you.
wong34539
Level 11
Level 11
try the following :
1. Go to the server and do a trace route to check that all devices are reachable and also be sure that all devices in the path are reachable.
2. Check the VTP configuration on the devices.
check out the following troubleshooting link for more information :
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_user_guide_chapter09186a00805af624.html#wp1184090
