High CPU utilization on CISCO3945 router
vithoba
Please help to troubleshoot this high CPU issue.
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(4)M6, RELEASE SOFTWARE (fc2)
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 987136K/61440K bytes of memory.
sh processes cpu sorted | e 0.00
CPU utilization for five seconds: 90%/88%; one minute: 88%; five minutes: 87%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
6 431973856 45106939 9576 0.47% 0.11% 0.11% 0 Check heaps
332 46964436 283618948 165 0.23% 0.24% 0.23% 0 CFT Timer Proces
255 115875220 60137923 1926 0.23% 0.21% 0.23% 0 FNF Cache Ager P
15 8087188 3714915037 1 0.23% 0.31% 0.31% 0 IP SLAs XOS Even
108 9495788 1163495752 8 0.15% 0.11% 0.12% 0 Netclock Backgro
89 15074552 291202200 51 0.15% 0.12% 0.13% 0 Per-Second Jobs
2 1072516 58175050 18 0.07% 0.07% 0.07% 0 Load Meter
353 4156 1485 2798 0.07% 0.24% 0.11% 648 SSH Process
137 2355876 2580562286 0 0.07% 0.11% 0.12% 0 Ethernet Msec Ti
5 Replies 5
Mark Elsen
  - FYI : https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15095-highcpu.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Joseph W. Doherty
Uh-huh, what's was the total traffic volume at that time?
Possibly, you're hitting performance limits of router.
BTW, I've attached a Cisco White Paper, that details performance results, for various tests, for various routers, including the 3945.
At the end of the document, Cisco recommends the basic 3945 for up to 150 Mbps WAN traffic, but that's very conservative.  I.e. Cisco's recommendation pretty much assures you'll not overload the router under 150 Mbps.  However, as the tests reveal, you'll often obtain more throughput than that.
Blue_Bird
Hello Vithoba,
Here is the Troubleshooting guide for High CPU utilizaiton:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html
Best regards
******* If This Helps, Please Rate *******
post the full running configuration of your router (sh run)...
